3D Interpolation
Old   July 14, 2004, 08:06
Default 3D Interpolation
Kyung-Seok, Kim
Hi! everybody. Now, I'm studying on 3D Multi-block method. But while I study above,I have some trouble. I hope you can help me.
Here is my problem.
There is 3D multi-block which consist of 2 block. and 'The bottom interface of upper block'(let's say B1) and 'the top interface of lower block'(B2) are NOT matched !
and I use FDM scheme,so I want to transfer potential information at grid point from B1 to B2.
and Now I try to use interpolation method.
Summarizing above thing, non-maching multi-block interface treatment of using FDM.
Q1)Is it right that I use interpolation like above problem?
Q2-1)If right,please recommend good reference,book and something like stuff.
Q2-2)If wrong,What am I gonna do ? ^^;
Thank you in advance.
I am waiting for your reply,Pro!
Old   July 14, 2004, 22:46
Default Re: 3D Interpolation
Halim Choi
Read following two papers given in the same journal issue : Numerical Heat Transfer: Fundamentals, Volume 32, Issue 4, December 1997
1.Computation of Unsteady Flows Using Non-Matching Blocks of Structured Grid by Lilek et al.
2. An Implicit Finite-Volume Method Using Non-Matching Blocks of Structured Grid by Lilek et al.
I had the papers, but I can not find them now. Thus I canot give you the detailed informations. I hope this helps you.
Good Luck
Old   August 17, 2004, 09:03
Default extreme points problem
Lipo Wang
Hello,everyone My problem is as follows: I have got the value of scalar at every grid point of a 256 cube and also have found these extreme points in this scalar field with a criteria of [S(i)-S(i+1)]*[Si-S(i-1)]>0, i should be in three directions: x, y and z. But we want more precise positions of these points, so interpolation is needed.
I tried to do interpolation and found some extreme points will dispear with the same criteria. This is due to the effect from no-adjencent points. For example, S(0,0,0) is extreme, then S(1,1,0), S(1,1,1),S(1,-1,0) are no-adjencent. So I wonder for interpolation, should I also consider these no-adjencent points, or only adjent points(totally they are S(0,0,1),S(0,0,-1),S(1,0,0),S(-1,0,0),S(0,1,0),S(0,-1,0))? Of course, more points considered, more reasonable. But more negative effect will destroy the criteria. How do you think about it?
Great thanks
Help on 2D interpolation in StarCCM+ madhuri Siemens 1 May 30, 2017 03:20
Interpolation Error on FAM Mesh with Cyclic BCs ngj OpenFOAM Bugs 1 August 9, 2011 06:12
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 14:32
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
