Urgent: Role of Reynolds No in NS Equations
Old   August 8, 2004, 07:47
Default Urgent: Role of Reynolds No in NS Equations
NIDurrani
Hi, I am validating my 2D RANS code for RAE2822 airfoil. The input conditions are Mach # 0.734 AOA 2.54 Re 6.5e+6 I am not clear how to corelate the Reynolds no with my code as i have used the dimensional form and Reynolds no is not used anywhere. Is it to do something with viscosity (meu) setting as Re= rho*u*L/meu.... Meu i am taknig as per Sutherlands Law with temperature as only variable. Thanks NIDurrani
Old   August 9, 2004, 02:35
Default Re: Urgent: Role of Reynolds No in NS Equations
Rami
NIDurrani,
Your Re definition is correct. It is common to use the free stream state velocity, density, temperature (and hence viscosity) and the airfoil chord length as the characteristic dimensions. From these you may calculate Re in your case. Equivalently, if you non-dimensinalize your (dimensional) equations wrt to the above characteristic dimensions consistently, then Re (and also Ma and Pr) will naturally appear in the resulting non-dimensional eqautions. This is a simple and recommended excercise.
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
Cell Reynolds Number laliong Main CFD Forum 12 September 17, 2019 03:18
About Reynolds Averaged Navier-Stokes Equations V. G. Ferreira Main CFD Forum 6 April 26, 2012 11:36
Turbulence: Reynolds stress equations kharicha FLUENT 0 March 16, 2006 08:50
Turbulence: Reynolds stress equations kharicha Main CFD Forum 0 March 16, 2006 08:48
