please suggest a CFD package which can do acoustic analysis
Old   May 18, 1999, 16:55
Default please suggest a CFD package which can do acoustic analysis
John Li
My Case is:
Induce an acoustic wave into a cavity filled with gas. The cavity maybe have hole connecting with outside. Analysises the acoustic wave resonance.
Does anyone know a commercial CFD software can apply to this case?
Thanks a lot
Old   May 18, 1999, 19:13
Default Re: please suggest a CFD package which can do acoustic analysis
Joern Beilke
If there is no fluid flow you don't have to solve the transient NS-equation. Just use an plain acoustic code or Ansys or ... It should be possible to do with most cfd codes but it is a huge wase of computing time.
If you have a turbulent flow and an acoustic wave you can also forget the stuff because the transient pressure fluctuations from the fluid flow are some orders of magnitude larger than the pressure fuctuations from the acoustic waves.
Old   May 19, 1999, 13:11
Sung-Eun Kim
FLUENT 5 has LES capability (or unsteady RANS) that you can use to compute the fluctuating pressure field. You can use the FLUENT data to compute overall sound pressure level. I understand several FLUENT users use this practical approach (using UDF) based on Lighthill's acoustic analogy to predict flow-induced noise, rather than relying upon full CAA.
Old   May 19, 1999, 13:37
Joern Beilke
You speake about pressure fluctuations within the flow field and not about sound.
Sound is something which is radiated to the far-field.
The pressure fluctuations in the area of acoustic sources do not need to produce any sound at all.
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 16:50
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
