SIMPLE on collocated grid
Old   August 17, 2010, 17:15
Default SIMPLE on collocated grid
dshawul is on a distinguished road
I am a newbie so please bare with me. I am trying to write a SIMPLE steady state solver on unstructured grid using collocated storage. So far it can solve convection-diffusion transport equations for a given correct velocity-pressure field. But I am now stuck on the pressure-correction for collocated storage of variables. It seems that from the momentum equation I can get velocity correction (at center) in terms of face pressure corrections by dropping the neighboring cells contribution (according to SIMPLE) :
up' =  Sum(N dot pf') / ap
From continuity :
Sum(N dot (rho * uf)) = 0
The velocity correction obtained from continuity is at the faces but the one I have from the momentum eqn is at the cell centers. How do I go on from this ? Do I just interpolate the corrections too and form a discretized equation ?
I was under the impression that the collocated scheme will be easier to implement atleast until I try to solve the "checker board" problem with rhie-chow or other methods. I have books but none of them give numerical example of SIMPLE on collocated grid, and I am content with having the checkerboard problem and other problems due to non-orthogonality of mesh at least for the time being.
Thanks in advance.
dshawul is offline   Reply With Quote
Old   August 17, 2010, 21:31
Ok I got it now. The velocity correction is actually not done at the centre but the faces. After an odd way of interpolating the coefficents (1/ap) , it will be similar to the procedure given in Patankar's book.
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
First order upwind on collocated grid arrangement Hooman Main CFD Forum 1 July 13, 2010 08:46
Stability of Collocated grid! Frederic Felten Main CFD Forum 8 November 2, 2009 05:00
Simple grid check query Ken FLUENT 0 March 27, 2007 00:47
Treatment of solid region in collocated grid Yongpan Cheng Main CFD Forum 0 December 10, 2006 22:27
