I wish to find the proper model to validate the temperature field.
Old   May 5, 1999, 12:43
Default I wish to find the proper model to validate the temperature field.
G.H.Lee
Hello! I implemented the turbulence modelling including temperature source term near the wall.(in case of standard k-epsilon model). Thus, I wish to compare calculated result with other published data concerning the natural convection problem. Would you like to inform me the simplest model. Again, It is the turbulence natural convection problem that I want to look for. Thank you.
Old   May 6, 1999, 02:05
Default Re: I wish to find the proper model to validate the temperature field.
Nuray Kayakol
At high temeperatures, a radiation model provides temperature source term (radiative energy source term)
you can use discrete ordinates method as radiation model for incorporation into your CFD code. It gives acceptable accuracy with computational economy.
NURAY KAYAKOL
Looking for SUBOFF model but i can't find it. Heewon Lee Main CFD Forum 7 March 5, 2017 13:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Adding temperature field to InterFoam yapalparvi OpenFOAM Running, Solving & CFD 8 October 14, 2009 20:18
High Combustion Temperature in the EBU model Mehdi Siemens 0 April 24, 2006 05:53
Please help a newbie find the drag on a 3d model David Amer Main CFD Forum 1 March 6, 2002 03:33
