Parallel computing
Old   August 12, 2004, 05:09
Default Parallel computing
jak
I am about to start a project that will need at least 6 3Ghz processors. I do not have the confidence to build my own cluster so can people tell me where I can buy such a pc off the shelf - preferably all the processors in the one box.
Regards
Old   August 12, 2004, 06:20
Default Re: Parallel computing
F.K.
Fujitsu-Siemens-Computers
www.hpcline.com
Old   August 12, 2004, 10:49
Ananda Himansu
Your shipping charges and red tape with customs will be less if you buy within the country you work in. Since you have given no indication of this, I will give you a general procedure.
Go to the largest bookstore in your city. Find some magazines on Linux. In the USA, these would typically be "Linux Journal", "Linux Magazine", and "Linux World Magazine". Another useful magazine would be "Scientific Computing", available online at www.scimag.com, although this is typically not restricted to PC architecture. Look through the ads (buy the magazines to support their continued publication). Note down the websites of ones that match what you are looking for. Begin researching on the WWW. Do let us know the results of your research, and also your degree of satisfaction when you finally receive your system and begin computing on it. I am sure your information will be helpful to others on this forum.
In the USA, I have heard good things about Linux Networx (http://www.linuxnetworx.com) and about Microway (http://www.microway.com) from people who have purchased clusters, but I have not been involved in any such purchases myself. You should be looking for 1U to 3U height (per blade) of rackmount clusters, to get as compact a system as possible. Many of the same vendors can also build you a Microsoft Windows based cluster, if that is your preference.
Old   August 12, 2004, 10:55
Ananda Himansu
I forgot to mention that of course you can go to the big players (HP, IBM, Dell). You should certainly use them and price and quality reference points, at the very least. On their websites, look for their "rackmount server" offerings. In fact, you could google the phrase and see what you come up with.
Old   August 12, 2004, 11:50
Jarmo Monttinen
Check out http://www.pssclabs.com/
-- Jarmo
Old   August 12, 2004, 15:37
Jonas Larsson
There are a few links to cluster vendors in the Resources/Hardware/Clusters/Cluster Vendors section here at CFD Online.
Old   August 13, 2004, 12:36
jak
I appreciate you all taking time to reply and I am currently looking into the various resources. I will post soon with some comparisons for others that may be interested and will update you on the cluster we go for.
Regards
Old   August 17, 2004, 12:26
Tom
Something you might want to consider is that for some programs, one box with six processors is slower than six boxes with one processor each. That is because some of the memory is used to handle the six processes. We use 10 2.6 Dell servers linked together with ethernet running LINUX and they only cost us about $2500 each (without rack). It is not a cluster in its true definition. I would recommend talking to your code's tech support people - ours gave us advice on configuration (not brands) and had us up and running within a day of getting everything assembled. TomK
unchangeable continuity residuals in parallel computing wlt_1985 FLUENT 0 August 1, 2011 12:15
Diffusion equation solved using Parallel Computing Sachin Paramane Main CFD Forum 0 June 11, 2007 23:48
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 15:54
Parallel Computing peter Main CFD Forum 7 May 15, 2006 09:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
