Free Surface Code Validation
Old   August 16, 2004, 19:24
Default Free Surface Code Validation
Maciej Matyka
What validation test would you suggest for free surface (without internal boundaries) code testing?
I am interested both: in simple cases with analytical solution available and in experimental/numerical results of recent/non recent works.
Best, Maciek
Old   August 17, 2004, 10:49
Default Re: Free Surface Code Validation
Doctor Blade
Prove with some analytical solution (if exist), or with Continuity or any global integral law validation of your numeric dates.
Old   August 17, 2004, 12:26
xueying
I validated my free surface results in a rotating bucket where the anayltical solution is available. You can find the analytial solution in the book 'transport phenomena' and the author is Bird.
Old   August 18, 2004, 02:48
Maciej Matyka
Would you like to suggest any existing case which has existing analytical solution?
Best,
Old   August 18, 2004, 02:49
Maciej Matyka
I don't have that book, but will try to find that case somwhere else. Thank you for pointing it to me,
Best,
Old   August 18, 2004, 10:05
Doctor Blade
First of all we have to know what are you solving.
Old   August 18, 2004, 10:45
Maciej Matyka
Incompressible free surface on staggered grid with SIMPLE method for NS solution and markers for fluid (surface) tracking. Is that enough? There is no need to give you an information about what I am solving actually, since the code I am developming is general, not for solution to one specificc problem.
Is that enough?
Old   August 18, 2004, 15:23
Doctor Blade
Well, if you don't especify any particular flow, analytical solutions are available for the round jet (Schlichting) and boundary layer (Blasius) flow. But those are for pressure gradient zero. All of them are self-similar solutions.
Old   August 18, 2004, 17:24
xueying
The following paper also uses rotating bucket as the testing case and the analytical solution in listed in this paper.
@article{Cairncross2000,
title = {A Finite Element Method for Free Surface Flows
of Incompressible Fluids in Three Dimensions.
Part I. Boundary Fitted Mesh Motion},
author = {Cairncross, R. A. and Schunk, P. R.
and Baer, T. A.
and Rao, R. R. and Sackinger, P. A.},
journal = {Int. J. Num. Meth. Fluids },
volume = {33},
pages = {375--403},
year = {2000} }
Old   August 18, 2004, 17:39
Maciej Matyka
Thank you, VERY much!
Maciek
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
CFX convergence issues with free surface adenlan CFX 3 September 2, 2011 06:43
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
Code with reliable free surface capability in a rotating system Subhasish Roy Choudhury Main CFD Forum 1 September 4, 1998 18:47
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
