Flat 2D surface immersed in 3D flow, is it possible? |
October 5, 2010, 12:39 |
César Vecchio
Rep Power: 15 |
Hello everybody.
This is my problem: I need to run a CFD simulation of a ventilation system, and the problem is that an important piece of the system is made from metal sheets. The only really problematic part is a metal sheet caping an extreme of an inlet with one of its edges free, and I cannot avoid its modelling so easily, but if I account for the sheet thickness it would lead to an unnecessary over refinement on that zone and maybe if I do it the run will not converge. I would like to know if I can represent this sheet as a simple 2D surface, that is a flat shape with no thickness, and then set it as a wall. Both sides of the sheet are wetted by the flow. I plan to use Code_Saturne. To show better my problem, please look at this picture http://www.absolutely-clean.com/cms_...hood_after.jpg. The sheet I'm referring too is the big square surrounding the extractor system (it's thin, don't get fooled by the bottom part which is a trough). It's not my geometry but rather similar. Thank you in advance. César |
Display Modes | |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
mapping flat surface to curve surface | wei | Siemens | 2 | June 26, 2009 08:10 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
Flow over surface | Duncan | FLUENT | 0 | January 26, 2006 11:05 |
