October 25, 2010, 16:26 |
shear velocity
fateme chegini
Rep Power: 16 |
Hi everyone!
I've been trying to validate my CFD code but wasn't successfull. If you could help me out it would be very appreciated: I want to model the flow field in an open channel and compare the velocity profile with the universal logarithm profile. In order to calculate shear velocity I've used the equation: usatr=U/C*(g^0.5) in which C is the Chezy coefficient and U the mean channel velocity. Now the problem is the numerical results don't match the logarithm profile. The question is: Is the method I use to compute shear vel wrong? Right now I'm assuming that the viscosity is constant. Thank's in advance for your help Good luck |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
shear stress/shear velocity | Zaktatir | CFX | 2 | June 11, 2010 04:01 |
Accuracy of wall shear and velocity | kjetil | OpenFOAM Running, Solving & CFD | 10 | April 27, 2010 13:35 |
How to calculate Velocity? | Kali Sanjay | Phoenics | 1 | May 1, 2006 13:57 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
