Fifth order anti diffusive scheme for 1D hyperbolic heat transfer
Old   November 3, 2010, 04:48
Default Fifth order anti diffusive scheme for 1D hyperbolic heat transfer
areffallah is on a distinguished road
Hello
Recently, Wensheng Shen et al published a paper as "anti-diffusive methods for hyperbolic heat transfer" that consider WENO as one of the anti-diffusive methods.
Link to download this paper:
http://www.cps.brockport.edu/~shen/p...iDiffusive.pdf
I am trying to review this paper and want to solve 1D hyperbolic heat transfer equation using fifth-order WENO. I have studied some papers about applying WENO, as listed below, But they couldn't solve my problem.
[1] A finite volume high order ENO scheme for two dimensional hyperbolic systems. By: Casper and Atkins
[2] Efficient Implementation of Weighted ENO Schemes. By: Jiang and Shu
[3] Essentially non_oscillatory and weighted essentially non_oscillatory schemes for hyperbolic conservation laws. By: Chi_Wang Shu
From This Paper I mean “anti-diffusive methods for hyperbolic heat transfer”.
I have two basic problems:
Considering This Paper, the corresponding mathematical model consists of the following two equations:
Where the following equation of characteristic variables will be obtained:
1) I want to apply boundary and initial conditions as below:
The dimensionless temperature of the slab is kept at T = 0 initially, and the temperature at the left boundary is increased to T = 1 at time t > 0. Two types boundary conditions are considered at the right end of the slab, given temperature (T = 0) and zero heat flux (q = 0).
Main problem is: How should I apply boundary and initial conditions. Because I can only specify either T or q but not both at boundaries. For initial conditions, I have only T and for left and right boundary conditions I have only one of T or q, therefore what should I do for another variable value? T and q or W1 and W2.
W1 = 0.5*(T + q) and W2 = 0.5*(T - q)
2) As explained in procedure 2.9. [3], I got the procedure for solving this problem as below:
At each fixed X(i+1/2)
1) Compute the right eigenvectors the left eigenvectors and the eigenvalues.
2) Using left eigenvectors, transform [T q] vector to [W1 W2].
3) Perform weno reconstruction procedure on W1 and W2 to obtain W1(i+1/2) and W2(i+1/2).
4) Transform back from characteristic to physical domain using right eigenvectors:
[T(i+1/2) q(i+1/2)] = R*[W1(i+1/2) W2(i+1/2)]
Where : R = right eigenvectors and Inv(R) = left eigenvectors.
5) Form the scheme below:
Where
And I consider two equations separately to solve (in this step I mean).
Is this procedure True? If not, please tell me what is my fault here.
areffallah is offline   Reply With Quote
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Heat transfer problem seojaho CFX 6 May 6, 2010 00:32
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 06:33
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
