Valve Boundary Conditions
Old   October 6, 2004, 10:01
Default Valve Boundary Conditions
Asok
I am modelling water flow through valves to find out the throttling characteristics.Basicaly I would like to know what will the mass flow rate for various valve openings.Assuming that the pipe incorporating the valve being connected to a centrifugal pump on one side and open to the atmosphere on the other end, what type of boundary conditions should I give for different valve positions.
Thanking you.
Old   October 7, 2004, 15:51
Default Re: Valve Boundary Conditions
Noora
The BC would be for pressures at the upstream of the valve(pump discharge pressure) and the downstream (atmospheric pressure). This in turn gives the delta P across the valve. This and the valve discharge coefficient Cv, will determine the flow as a function of valve opening provided the fluid density is known. Want more, Don't hesitate.
Old   October 8, 2004, 05:16
Asok
Thanks Noora.I am happy that I had also thought in the same lines.The point to be further decided is what should be the value of the upstream pressure.(1)Whether it is the pressure value obtained when the valve is fully shut or (2)the pressure corresponding to the velocity of water when the valve is fully open or (3) the pressure corresponding to the manometric head of the pump.
Regards and thanks.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 06:25
