December 6, 2010, 11:15 |
Time step at coarse grids
SSSS
Hello all.
I am writing a 2D cell-centered Cartesian laminar solver accelerated by multigrid technique in C++. I have a problem at cases having low reynolds number. For determining time step, I used local time stepping in the article "Multigrid Solution of the Navier-Stokes Equations in Triangular Meshes" by D.J. Mavriplis. It gave good result when multigrid is not used. However, when multigrid is used, pressure became minus so quickly. Euler equations are solved in coarser grids even if the flow is viscous. For time step, the local time stepping above is used. When I change time step calculations to the time stepping for inviscid case or I solve Navier-Stokes equations for coarser grids, pressure became minus again in the first cycle. How can I determine time steps for coarser grids? What is my mistake, here? Thanks for all replies: ) |
Changing deltaT of current time step | olwi | OpenFOAM Running, Solving & CFD | 1 | April 30, 2009 04:55 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
