November 4, 2004, 13:23 |
cascade flow periodicity
can anybody suggest a logic for implementing periodic boundary conditions on Unstructured meshes for a turbine cascade flow. unstructured mesh has random numbering of cells.so how we can implement periodic boundary conditions ? thank you
November 7, 2004, 00:44 |
Re: cascade flow periodicity
The random numbering of cells makes implementation of BC a problem. You will have to define more variables to handle this. What I suggest is this: in the face data structure (or the edge data structure in case of 2D), define a TAG variable which will have values like BCupper, BClower or BCwall depending on the type of boundary the face lies on. While updating the values during the scheme keep a check if the current face is on boundary using TAG variable.
After each iteration you need to update values on the bdrys in accordance to periodic condition. You can traverse through all the faces, checking the TAG value and update BC accordingly. On the matter of how to know if the face lies on boundary or not, it depends on the data structure implemented to store the mesh. In case of half face data structure, we check if the twinface of the face is NULL. Hope this helps... |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
