Help with calculating turbulence parameters!
Old   January 16, 2011, 15:02
Default Help with calculating turbulence parameters!
Dan Chambers
Dan Chambers is on a distinguished road
Evening all,
I'm trying to calculate the boundary turbulence parameters for a case. I am modelling a flat plate (0.76m x 0.406m) with two strakes on to generate vortices.
From experimental data I know the turbulence intensity is 2% and I have set the turbulent length scale to be 7% of the plate width (0.028m). I have also assumed in the calcs below that the mean flow velocity is the freestream value of 53.6m/s (not sure if this is correct or not).
Using the calculation in the fluent manual (http://combust.hit.edu.cn:8080/fluen....htm#ke-params) I find the following values:
Turbulent kinetic energy: 1.723776
Turbulent viscosity ratio: 1354.598
Dissipation Rate: 13.08516
From this I'm pretty sure I'm doing something wrong as I was expecting the turbulent viscosity ratio to be below 10!
Can anyone please offer me some advice on this as I'm completely at a loss as to what I've assumed wrong to make the calculations give such wrong numbers. Any help is very much appreciated.
Many thanks
Dan
Dan Chambers is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence model parameters Vidya Raja FLUENT 2 October 6, 2006 13:38
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
How to set turbulence parameters at periodic BC? Ray FLUENT 2 July 28, 2000 04:15
