From pressure to velocity
Old   December 10, 2004, 16:21
Default From pressure to velocity
Rodrigo Madariaga
Hello CFD Community, whenever I need help, I know I can count on this forum so her goes my question:
I am trying to find the best nozzle for a Oxygen tube. Before I start modifying the nozzle, I am trying to simulate a simple evacuation of oxygen through a pipe. In my experimental facilities, I have the oxygen going through a hose that goes to a manometer and then comes the pipe (3/8in diameter). The manometer reads 40 psi and I havent measured the velocity yet. I made a fluent model of this and in my pressure inlet boundary condition I put the 40 psi in the gauge total pressure. The problem is that when I initialize the solution, the speed starts an 400 m/s wich in my opinion is too much. I cant even start the solution because I know the initial solution is wrong, Does anyone know what is going on? Please help me, thanks.
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Pressure Velocity coupling problem Sunho park OpenFOAM Running, Solving & CFD 0 August 4, 2010 00:22
Pressure jump on supersonic velocity inlet Viktor FLUENT 0 August 9, 2007 00:23
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 20:04
how to print the results from CFX-4.2 cfd_99 Main CFD Forum 5 June 21, 1999 09:23
