meshing air lift
Old   January 15, 2011, 15:57
Default meshing air lift
hossein
mahmoudihossein is on a distinguished road
hi mr or miss
i have a problem in meshing my case that is a airlift consist of 8 holes with 0.0003 meter diameter.
please let me know how you mesh your case's holes or if it is possible send me your mesh.
sincerely yours.
hossein mahmoudi.
mahmoudihossein is offline   Reply With Quote
Old   February 1, 2011, 07:43
Marcelina
gagi3 is on a distinguished road
I suggest you to change shape of sparger hole from circle to square with the same area ( You should to use hydraulic diameter of single hole). If you use circular holes, computational sparger area will not be equal to real area because of low mesh quality around circular sparger holes.
Best regards
gagi3 is offline   Reply With Quote
Air Lift Pump BCs ramesh.gannamani FLUENT 0 July 20, 2009 17:10
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Airfoils and lift compared to air density and TE Jens Main CFD Forum 0 May 4, 2006 03:31
Meshing Micro Air Vehical (MAV) in Gamibt Xiongjun Shao FLUENT 0 January 9, 2005 17:52
i need help meshing a 3d body for lift analysis chris FLUENT 2 September 19, 2003 02:36
