December 16, 2004, 09:31 |
PREMIX code - usage?
Dear CFD/combustion colleagues,
I'm trying to use PREMIX code from CHEMKIN II package in a freely propagating flame configuration + hydrogen chemistry. Question: How one sets appropriatelly the initial guesses for the product and intermediate species composition? The same with the temperature profile? Does one has to specify intermediate species at all or program handles such situations alone, without user supplied input? So, if someone of you uses PREMIX code, please give some short hints on upper questions. Thak you! |
December 19, 2004, 09:29 |
Re: PREMIX code - usage?
When computing chemically reacting flow, if the chemical reaction scheme can spontaneously produce all species, then you need not to prescrible the intermediate speices. However, in some cases, you need to specify intermediate species when there are no reaction chanels to a species. Specify a very small number of it, say, mass fraction of 10^_{-11}.
December 19, 2004, 11:41 |
I tried it that way in meantime, and it seems to work - just as you said! Thanks for info, anyway.
Regards |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Debugging Unsteady 2-D Panel Method Code: Wake Modeling | RajeshAero | Main CFD Forum | 5 | November 10, 2011 05:48 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 04:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 11:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
