December 23, 2004, 08:22 |
I want NACA0012 simulation datas
Hi.
I hope to simulate NACA0012 airfoil numerically at low Reynolds in laminar flow. B.C. my code is incompressible code. So I tried to search some numerical/experimental datas(like Cp, Cl, Cd) of NACA0012 at low Reynolds and laminar flow. But mainly the reference datas are results of Compressible flow (numerically)at Mach=0.8 or 0.5. So How to get the reference value of NACA0012 airfoil at low Reynolds in laminar flow ? |
December 23, 2004, 08:33 |
Re: I want NACA0012 simulation datas
Here's two useful refs for NACA 0012 data:
1) "NACA0012 Airfoil", AGARD Advisory Report, Thibert, J.J. and Grandjacques, M. and Ohman, L.H., 1979. 2) "Low Speed Aerodynamic Characteristics of NACA0012 Airfoil Section, Including the Effects of Upper Surface Roughness Simulation Hoarfrost", National Physical Laboratory (NPL), Gregory, N. and O'Reilly, O.L., 1970, No. 1308. Regards James |
December 28, 2004, 11:58 |
Hi there,
1)- Check the following webpage: http://www.unibas.it/utenti/bonfiglioli/node10.html It might be useful if you want to validate the viscous terms of your code. There are some velocity profile available. Keep in mind that these are only numerical results that Bonfiglioli performed. 2)- Also check the following paper: Yu D, Mei R, Shyy W. "A multi-block lattice Boltzmann method for viscous fluid flows". Int. J. Numer. Methods Fluids Vol 39, pp 99–120, 2002 They apparently evaluated their numerical scheme by computing the flow around a NACA 0012 for Re=500; 1000, 2000, and 5000. Again, these are numerical results and not experimental data. Hope this might help. Good luck Frederic Felten |
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
NACA0012 compressible static simulation | paolopaolo88 | OpenFOAM | 1 | April 14, 2011 10:29 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
