Pressure computation on inlet
Old   December 30, 2004, 07:05
Default Pressure computation on inlet
Diego Nogueira
Greetings everyone,
I have a doubt on pressure boundary condition on inlet. I'm trying to simulate smtg as simple as an incompressible flow on a flat pipe, for instance.
I've seen this:
Pi = Pn - 2(Vn-Vi)/(dx*Re)
Pi -> pressure @ inlet. Pn -> pressure @ neighbor cell, Vn -> y-component of air velocity @ inlet
The problem with this is that since Pn depends on Pi and vice-versa, at some point on my computations these values explode while I was expecting them to reach a stable value at some point.
Could you help this poor CS guy? Are there any other options?
Old   January 3, 2005, 02:31
Default Re: Pressure computation on inlet
agg
Try this:
1)Make sure your discretization is correct for the viscous term.
2) In your pressure solver (I assume you are solving a poisson equation) do not solve for Pi. i.e. solve only upto Pn. Now, you need to supply a boundary condition for your poisson equation at Pn. For this, use the following neumann condition, namely (Pn-Pi)/dx = 2(Vn-Vi)/(dx*dx*Re)
3) Once you get the pressure solution at all internal points including Pn, use Pi = Pn - 2(Vn-Vi)/(dx*Re) to compute Pi.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 21:32
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
about pressure inlet boundary Sastry(CFD Forum) FLUENT 0 February 19, 2007 02:55
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
