January 2, 2005, 20:38 |
DENSITY...
Hi! I have one question about a finite-volume code I am writing.How can I descritize the continuity equation?The code goes like this:I solve the u-v-w momentum,then I try to solve continuity and update the density field(and from the equation of state the pressure field).Then I solve energy equation and k-epsilon equations.But I have seen that something doesn't look wright with the values of density.The code is about compressible flow (Mach=0.3). Thank you!!!
January 5, 2005, 12:07 |
Re: DENSITY...
Can you tell me the algorithm how to discretize continuity equation? dr/dt+d(ru)/dx=0 THANK YOU
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 14:20 |
Variable Density Function | ryzd | FLUENT | 1 | August 25, 2011 14:16 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
variable density water | Atit Koonsrisuk | CFX | 2 | July 24, 2003 03:07 |
