February 5, 2011, 12:06 |
Low reynolds number flow
pranav r
Rep Power: 15 |
What are the equations aplicable in the case of a low reynolds number flow as in the case of a flow past an airplane made of paper
February 8, 2011, 04:29 |
Muhammad Aqib Chishty
Rep Power: 15 |
depends upon the problem and your area of interest....
Reynolds Averaged Navier Stroke's Equation(RANS).... is to be the best to catered flow separation |
February 16, 2011, 05:35 |
Rep Power: 15 |
hi,
i want to calculate the Reynolds number of exhaust gas with a given temperature(°c) and massflow(g/s). What is the fastest way? thanks in advance |
February 17, 2011, 00:51 |
Rep Power: 15 |
i think as per my knowledge, your flow is compressible and their should be some laminar separation....
the best model to catered that is Menter Transition model of 4 four equations.... |
February 21, 2011, 09:53 |
Shenren Xu
Rep Power: 15 |
February 22, 2011, 10:42 |
#7 | |
This thread is about aerodynamics of a small (paper) airplane. Have you seen shok waves past paper airplane? BTW, for inviscid fluid RE=infinity |
February 22, 2011, 11:04 |
Shenren Xu
Rep Power: 15 |
Hi truffaldino,
my apology... I didn't read it carefully. And you are right, Re # is infinity. hope my advisor is not reading this... |
February 22, 2011, 12:36 |
#9 |
Vasiliy
Rep Power: 15 |
Hi All,
My opinion that transition model is not necessary in this case. As I understand air flows around paper plane. So velocity is small and we can use incompressible Navier Stokes equation. About turbulence models. I think SA model is good choise in this case. Flow is not very difficult. I am not sure about transition and separation on paper plane. |
February 23, 2011, 01:00 |
#11 |
Vasiliy
Rep Power: 15 |
Hi truffaldino,
It looks like nice case. It would be interesting to have such model and experiment results. Could you provide it. Thanks |
February 23, 2011, 02:33 |
#12 |
Hi Vasiliy,
Information about low reynolds number airfoil design and its peculiarities (due to separation/transition bubbles) is quite extensive and easily acessible over the web. As an example you could take a look at Martin Heppelere website, and in particular http://www.mh-aerotools.de/airfoils/ Data on very slow airfoils for Discus Launch Gliders (down to RE=40K) can be found here http://www.charlesriverrc.org/articl...t-airfoils.htm People from RC glider commmunity mainly use Mark Drela's xfoil and also XFLR5 software. These are nice programs that are free and increadibly easy to use: Xfoil analyses airfoils, while XFLR5 analyses an airplane as a whole. These programs are based on viscous-inviscid interaction method with boundary layer integral methods. They use e^n transition model and some turbulence model. One can also have a rough idea about presence of separation at low Re for 2D airfoils even without using the above software: one can use Thwaites integral BL method. It is very simple and takes a couple of hours to write a program in mathlab or maple. About experimental data: there has been an extencive testing by UIUC Applied Aerodynamics group, and measured polars were available free of charge on the web. Now they are selling them as reference books: see e.g. http://www.ae.illinois.edu/m-selig/uiuc_lsat.html but some of them are still scattered over the internet free of charge Truffaldino Last edited by truffaldino; February 23, 2011 at 06:16. |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Reynolds number for flow over half cylinder? | Haroon10 | Main CFD Forum | 0 | April 23, 2009 10:09 |
Coupling of RNG k-e and Low Reynolds number k-e | Amaranath | FLUENT | 0 | January 16, 2008 08:08 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
