February 24, 2011, 10:03 |
Why does vortex shedding occur?
TWB
Rep Power: 19 |
I have read some articles and papers on vortex shedding. Most simply describe the phenomenon and where and when it occurs, but does not give a physical explanation as to why it occurs.
For example, a simple flow past a cylinder. Why does vortex shedding occurs after a while? Can someone give a clear physical explanation? Thanks! |
February 28, 2011, 18:55 |
Rep Power: 16 |
you must already be aware that it happens because of adverse pressure gradient etc
i had the same question and i believe it is the inherent non uniformity in the inlet flow that triggers the vortex shedding (this might answer why shedding happens first from top or bottom of cylinder) but what about numerical simulation? what if the inlet flow i specify is uniform, without turbulence and the grid generated is also symmetric about, say, horizontal line passing through center of cylinder? which side of cylinder (top or bottom) will first trigger seperation? do round off errors play a role here? I was digging into this at some point but then left halfway.... thanks for reminding.... i will again work on it.... let me know if you find something useful |
March 1, 2011, 05:33 |
The simplest explanation in my view reminiscent to that of Kelvin-Helmholtz instabilities when strong velocity shear is present (in BL with velocity inflection point or in recirculation regions): A non-zero curvature perturbation of "dividing" streamline will lead to a slight centrifugal force which in turn leads to a change in pressure thereby amplifying the ripple and stronger and stronger amplification and shedding the vortices.
March 1, 2011, 09:28 |
#4 | |
private
Rep Power: 17 |
I asked Dr. R. A. Gentry of that group how the shedding was initiated numerically. As best I recall, he answered "I'm sure we perturbed the inlet flow. We couldn't wait around for some random fluctuation to trigger it." Hope this is useful. OTD |
March 1, 2011, 19:37 |
Hua Zen
Rep Power: 17 |
I have the same question. In reality it could be the perturbation of the incoming flow that trigger the vortex shedding. But what cause it in numerical simulation with homogeneous incoming flow and symmetrical configuration? Now the only explanation I could find is round off error when using the floating point calculation.
March 1, 2011, 19:59 |
#6 | |
private
Rep Power: 17 |
I suppose round-off or using difference algorithms that break the symmetry imposed by the boundary conditions could trigger shedding in a homogeneous inflow as well. |
March 1, 2011, 22:11 |
Derwin Parkin
Rep Power: 16 |
Yes Round-off can trigger it. I have run laminar simulations past cylinders and noticed shedding occur, with 100% uniformity in the flow. The only explanation I and my colleagues agreed on was Round-off error.
But also, if you were to use a turbulence model, applying a level of turbulence at the inlet will speed up the process. The turbulence model you select will also play a role in the shedding of vortices - for example, L.E.S. is much better than just running a transient SST simulation. |
Vortex in an intake pipe, critical submergence | Julien Pralong | FLOW-3D | 1 | October 23, 2010 15:24 |
creating vortex core line | aay023 | Main CFD Forum | 0 | September 15, 2010 21:49 |
Air-Jet Vortex Generator, request for some papers | ROOZBEH | FLUENT | 0 | July 12, 2008 10:28 |
Air-Jet Vortex Generator, request for some papers | ROOZBEH | Main CFD Forum | 0 | July 12, 2008 10:27 |
turbulent scales of forced vortex and free vortex | lcw | Main CFD Forum | 3 | September 1, 2005 13:40 |
