March 28, 2011, 12:46 |
what's R-refinement and h-refinement?
L.Y LIN
Rep Power: 16 |
plz explain them ,thanks.
March 28, 2011, 12:50 |
L.Y LIN
Rep Power: 16 |
ok,i have found the answer:
In the first, h-refinement, increased local resolution of solution features is accomplished by recursively subdividing mesh cells where needed. This technique is used by both the Cartesian grid and the unstructured grid communities. In the second category, r-refinement, the number of mesh nodes and cells remains constant, but nodes are relocated to areas where needed to increase resolution. It can be argued that each type of reŽnement will produce acceptable resolution improvement under appropriate usage. |
Display Modes | |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
[snappyHexMesh] sMH refinement level | subhkirti | OpenFOAM Meshing & Mesh Conversion | 0 | October 13, 2010 05:10 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
