k-omega, cross diffusion
Old   February 9, 2005, 17:01
Default k-omega, cross diffusion
Emre
I am trying to implement k-omega turbulence model. For free shear (wake), turbulent visciosity is increasing. I have to increase w porduction but how? adding cross diffusion is not enough. Any help will be appreciated.. thanks
Old   February 12, 2005, 06:25
Default Re: k-omega, cross diffusion
dd
It would be preferable to use a mixed model of k-w - k-e type (BSL Model) dd nvs
Old   February 12, 2005, 17:19
Emre
Thank you very much for responding. I get over the problem by multiplying w production by an artificial constant (between 1-10) that is dependent on the w value and aspect ratio (which affects the diffusion of omega) of the grid cells. But I will definitely start modifying to BSL method. One more general question. How the wake calculations affect the values in the wall boundaries of airfoil? Would the smoothing that I used (made up) affect the solution too much?
Old   February 13, 2005, 09:23
dd
Hello, Emre I am very busy, therefore i will answer you a later. But I think that the paper of Balakumar(**) can bring brief replies to you se you soon dd ** : P. Balakumar, Computations of Flow Over a Hump Model Using Higher Order Method With Turbulence Modeling , 43rd AIAA Aerospace Sciences Meeting and Exhibit, Reno, Nevada, AIAA 2005-1270, January 10-13, 2005, pp. 20
Old   February 13, 2005, 16:24
Emre
Thank you dd. I will search for this paper. see you..
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 12:52
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 9, 2011 23:25
implementation of diffusion coefficients and use of diffusion coefficients stephan OpenFOAM Running, Solving & CFD 0 February 28, 2010 14:30
Species diffusion coefficient iceabc FLUENT 1 June 10, 2004 10:04
