Cooled walls
Old   February 15, 2005, 10:50
Default Cooled walls
sparrow
in a conserved scalar combustion model of a flame in a chamber, how can i deal with cooled walls?
as the mixture fraction is conserved i dont think i can just set this to a particular value at the boundary as this will not be consistent. i think i have to use a zero gradient assuption at the wall.
also anything i do to the scalar at the wall must also surely implicate the other species that are related to the mixture fraction?
is the answer to make the temperature no longer a function of mixture fraction? if this is the case can the other speicies still be a function of the mixture fraction, as surely the temperature change will effect the burning, so how does the temperature changes feed back to the species?
any help would be great.
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 12:51
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 11:49
Heat loss through walls franzdrs Main CFD Forum 2 September 30, 2009 06:33
heat transfer from hot gas to cooled vane Chris Avenell Main CFD Forum 2 August 23, 2005 16:27
thermal conditions of walls Stefan FLUENT 2 March 23, 2003 06:17
