Kiva3v2 under RedHat Linux9.0???
Old   February 16, 2005, 20:26
Default Kiva3v2 under RedHat Linux9.0???
lq3088066
Hello everyone:
I am new with RedHat Linux9.0, and Kiva3v2 can not be complied properlly, the problems are: 1. How to specify real type as double precision; 2. when nv is big enough, the program will not be run (PC with 1.0G RAM).
Help needed! Thanks in advance.
LiQiang
Old   February 19, 2005, 03:47
Default Re: Kiva3v2 under RedHat Linux9.0???
Z
which compiler do you use. I have not problem in red hat linux 9.0. Can you send me your makefile. Can you show the error which you get. Z
Old   February 19, 2005, 08:50
lq3088066
The compiler in ReadHat Linux 9.0 is G77, and in kiva3v2 there is real variable have a big value up to 1.0E+100, and because the variable is defined as real type which has a word length of 32bit by default in G77, so INF is occured. Can you help me with it?? Thanks in advance
Old   February 20, 2005, 02:38
Rami
For most compilers, the -r8 option will enforce 64-bit reals throughout.
Old   February 21, 2005, 04:14
Z
Is it working with Rami's advice. Actually we are working with ifc(version 8) compiler. as far as I know it is free why do not you install it and recompile everything. Z
Old   February 24, 2005, 20:22
lq3088066
I have installed the Intel fortran compiler 8.1 on my Linux and it works well. Can you help me on the best set of command option , I do simulation on PC, one processor , 512 RAM and Intel Pentium4
[Netgen] Netgen segfaults tetmeshing on Redhat EL5 djvictoid OpenFOAM Meshing & Mesh Conversion 1 June 11, 2011 06:53
I want to know how to find out the latex in redhat KK Main CFD Forum 4 July 5, 2007 04:00
C++ manual for RedHat 9.0 Abhijit Tilak Main CFD Forum 12 September 16, 2004 03:44
CFX5.6 on Redhat 9 Jingo CFX 5 July 31, 2003 17:09
Setup on Redhat Linux 8.0 / OpenMotif Library Steve Lewis Siemens 3 April 3, 2003 10:20
