Calculating displacement and momentum thickness from Fluent
Old   April 14, 2011, 13:45
Default Calculating displacement and momentum thickness from Fluent
Vipul
VSAndroid is on a distinguished road
I am trying to find the displacement thickness and the momemtum thickeness on a flat plate.
I have obtained the mean velocity profile at two stations in the wind tunnel and it gave the boundary layer thickness that matches experimental data.
However, I am struggling to calculate displacement and momentum thickness.
my Re value is 10^6 so the flow is Turbulent. I am guessing I will be using Turbulent boundary layer displacement momentmtum thickness equations to calculate these values right? :S
I am so confused. Please help.
VSAndroid is offline   Reply With Quote
boundary layer, displacement thickness, momentum thickness
Momentum and displacement thickness: du/dy calculation Josh CFX 13 October 27, 2013 14:38
general momentum source/hydraulic pressure jump/positive displacement machine ckleanth CFX 10 August 25, 2012 06:23
Displacement and momentum thickness ganesh FLUENT 1 April 15, 2011 10:47
UDF to compute displacement thickness zitzitoun FLUENT 0 October 6, 2009 10:48
