February 24, 2005, 22:04 |
How surface tension affect delta t?
For two fluid flow with strong surface tension (VOF method, no phase change), how does it affect determing delta t? Is there any dimensionless number (such as Courant number) that can be used to roughly calculate the maximum delta t for stability (transient problem)? Regards, Pei |
February 25, 2005, 00:55 |
Re: How surface tension affect delta t?
There is a nondimensional number related to surface tension effect, We, Weber number.
February 25, 2005, 09:54 |
HI, Junseok,
Thanks for the reply. I understand that Weber number is the ratio between inertia force and surface tension force. But, for CFD, how to use this number to calculate maximum delta t allowed? Using Courant number as an example: delta t = CFL * delta x / maximum velocity Pei |
February 25, 2005, 10:55 |
Take a look at Mark Sussman1 and Elbridge Gerry Puckett's paper. You will find what you wanted.
Journal of Computational Physics 162, 301–337 (2000) A Coupled Level Set and Volume-of-Fluid Method for Computing 3D and Axisymmetric Incompressible Two-Phase Flows |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
continuum surface tension model | yukn | Main CFD Forum | 0 | October 8, 2011 06:43 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 12:19 |
How much surfactant affect surface tension | qunwuhe@hotmail.com | Main CFD Forum | 0 | June 7, 2007 05:01 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
