March 2, 2005, 01:09 |
Does RSM use wall function?
Just have a quick question for LRR or SSG Reynolds stress models. Does these models use wall function to model the near wall flow? If so, we will need to consider the Yplus limit, right? If not, How can the near wall flow be modelled if RSM is used. Thanks for any comments here. |
March 2, 2005, 03:37 |
Re: Does RSM use wall function?
Yes, they need wall functions, with all the limitations that brings in. There are also some low-Re Reynolds stress models in literature, but I have never implemented one myself. Rumour is that they are very unstable/dificult to solve and don't give you the benefit you expect (but my news may be a generation behind the "latest and greatest").
Hrv |
March 2, 2005, 18:31 |
Hi Hrvoje,
Thanks for your comment here. I recently run a case using a pretty fine mesh near the wall. No problem to converge if k-w/k-e model is used. When it comes to RSM, it just doesn't want to converge properly. I guess RSM is more sensitive to the Y+ value in this case ( I say so because when I increase the wall distance from first node, it does improve the convergence). Just wonder why..... |
March 2, 2005, 21:53 |
I am not a turbulence modeling expert; however, a google on reynolds stresses and near wall showed the following: It probably is what you want, and it comes from one of the big school in turbulence modeling: http://personalpages.umist.ac.uk/sta...r/turbcfd2.pdf Good luck, and let us know how it goes JC.. |
March 2, 2005, 23:58 |
Hi Jc,
Thanks for the link. It's really handy. I think there's some low-Re kw-RSM models available as well.... I'll try it out later... |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Question about wall function | Gary | Main CFD Forum | 1 | December 3, 2007 10:54 |
Wall function problem in Fluent | mefpz | FLUENT | 1 | October 10, 2007 13:43 |
