May 3, 2011, 18:06 |
gfortran compilation
Hassan
i have a code in gfortran...
i need to change the code so obviously i need to see that whether changes r fine or r there any errors.. so how can i compile the code for errors?? and then how to Run it... regards |
May 3, 2011, 23:41 |
Rep Power: 19 |
Suppose your program is named test.f90, open a Command Prompt in the folder where your Fortran code is placed and write:
gfortran test.f90 -o test.exe If you will see no error messages and you will obtain a new file test.exe then your original program was free of syntax errors. If you want to run the new program just write in the same Command Prompt window: test.exe Do |
May 4, 2011, 18:16 |
Try this:
gfortran -g -o Output Program.f90 Output being the executable. The option -g allows the compiler to generate debug symbols for debugging. The compiler should catch syntax errors automatically. if you are on linux you can use the gnu debugger to debug the code. I don't know what to use on windows. |
May 4, 2011, 20:08 |
@Eezyville
"I don't know what to use on windows." On Windows you will use the same gdb debugger ... |
May 4, 2011, 22:58 |
Hassan
thanks to all. ill check this gnu debugger....
errors during compilation and installation of OpenFOAM-1.7.x on Ubuntu 10.04 | ftec | OpenFOAM Installation | 7 | February 23, 2011 06:07 |
Compilation Order and Single Precision Issues | gocarts | OpenFOAM Bugs | 1 | October 14, 2009 17:19 |
Compilation Error when running Tutorial 2.4 | zhihuali | Siemens | 7 | April 1, 2008 07:34 |
Compilation error with uparm.f | Raghu | Siemens | 2 | May 30, 2007 02:09 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
