May 14, 2011, 02:41 |
Number of nodes for LES And DES
mohammad
Rep Power: 16 |
Hey guys,
I have heard that there are some quantitative equation( as rule of thumb) between number of nodes and "Re" number for DES and LES methods. Do you know anything about this matter? |
May 14, 2011, 23:33 |
#2 | |
Vieri Abolaffio
Rep Power: 16 |
DNS for the same flows is around Re^3 and Re^3.6 Dont' know about DES, sorry. you can obtain those figures using the definition of kolmogrov lenghtscale for the free shear and the friction velocity for the wall bounded flow. |
May 14, 2011, 23:53 |
#3 | |
mohammad
Rep Power: 16 |
My case is a NREL wind turbine and the average Re in my case is between 500,000 to 900,000( the Reynolds is calculated locally according to the local air velocity and chord). The average chord is 0.5 m and the blade span is 5m. I've put 53 nodes in chordwise and 83 in spanwise directions and based on CFX Post results my Y+<1. I paid attention to have finer mesh near the blade and further away mesh is coarse. the total number of nodes are about 5. million. for the case above, do you have any suggestion about the number of nodes I need ? Thanks a lot |
May 15, 2011, 00:13 |
#4 | |
Vieri Abolaffio
Rep Power: 16 |
but 50 pts chordwise and 83 spanwise looks a little bit coarse, have you done mesh indipencece studies yet? just as a rule of thumb: y+ < 1 ok and also x+ < 100 and z+ < 20 |
May 15, 2011, 00:31 |
mohammad
Rep Power: 16 |
Actually I'm doing mesh sensitivity test now. I'm doing it for steady state case using SST model. At the same time i'm changing No. of nodes to make my model ready for DES or LES. What I have got till now is that DES is more efficient than LES for my case( regarding the time and machine power). but still i'm trying to understand the least adequate no. of nodes for my case for DES. If my model needs very large number then I should think about using a better PC.
which one is chordwise direction here? z or x? plus, how to calculate the values of x+ and z+ manually? Are they available in CFD result file? |
des, les, number of nodes |
Spanwise Length and Grid Refinement for SAS-SST, DES, and LES | Josh | CFX | 5 | October 14, 2010 19:47 |
How to use DES well? | Daniel | Main CFD Forum | 0 | October 26, 2008 05:59 |
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body | Phil | Main CFD Forum | 0 | January 8, 2008 09:04 |
Problem with DES analysis | mehul | CFX | 7 | April 25, 2006 07:57 |
Problem with DES model | mehul | Phoenics | 0 | April 12, 2006 08:00 |
