May 17, 2011, 04:12 |
Melting Aluminum by molten Steel
Rep Power: 15 |
The problem i'm dealing with involves the pouring of molten steel into enclosure which contains an aluminum block. I'm looking for a CFD software best capable of predicting the flow and heat exchange between the molten steel and the aluminum block. I would like to know the temperature the aluminum block achieves and whether it melts or not. Modeling the melt process of the aluminum block is a nice-to-have. In such case, I guess it becomes a 3 liquids problem (molten steel, molten aluminum and air). Is there any CFD software capable of performing such calculations? I would appreciate your help a lot!! Thanks Last edited by leff; May 17, 2011 at 10:36. Reason: title correction |
casting, cfx, fluent, melt, vof |
Fluent Melting Feature | William Kong | FLUENT | 2 | June 19, 2014 12:52 |
Simulate melting process of solid aluminium in liquid Titanium | anirudster | CFX | 8 | March 21, 2014 09:20 |
Modeling of Melting | James | FLOW-3D | 4 | March 8, 2009 00:27 |
Solidification and melting with CFX | Don | CFX | 0 | December 1, 2008 11:30 |
Is UDF the only way to handle particle melting? | marq | FLUENT | 3 | February 23, 2008 01:48 |
