Two different methods for modeling a rotatory system |
January 16, 2012, 02:37 |
Nav
Rep Power: 14 |
There are two possible methods for modeling a rotatory system (such as a water turbine),
1) using a moving mesh 2) fixing the blades, and rotating the housing employing an angular velocity boundary condition. (fixed grid) It is clear that the second approach is much easier to implement. I wonder to know their differences? Do they both result in similar results? Thank you very much, Last edited by nav; January 17, 2012 at 01:51. |
January 18, 2012, 11:33 |
Rep Power: 14 |
Actually, if you are modelling an internal flow, you need both. You need to rotate the whole mesh (the rotor turning) and then apply a reverse rotation to the boundary (since the wall should be static). Otherwise the system will look static from the fluids point of view.
CFD engineering resource |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Need ideas-fuel discharge system | Jan | FLUENT | 1 | October 10, 2006 23:05 |
Need ideas-fuel discharge system | Jan | CFX | 1 | October 9, 2006 08:16 |
need ideas-fuel discharge system | Jan | Siemens | 0 | October 9, 2006 04:31 |
Need ideas-fuel delivery system | Jan | Fidelity CFD | 0 | October 9, 2006 04:30 |
