MPI buffer size for Send/Recv
Old   April 14, 2005, 08:36
Default MPI buffer size for Send/Recv
scicomex
I am using Scali MPI in my code. I use the MPI_Send() and MPI_Recv() routines for sending information between the nodes. I increase the amount of data that is sent between nodes and everything works fine, until a certain amount of data when the communications just become idle and the program gets stucked, as if the different processors do not receive the information they are waiting for and just keep on waiting for ever.
I have read something about the size of the buffer that is assign for MPI communiations. Could that be the problem? That I am sending more information than the maximum buffer size?
In this case, if I change to the nonblocking routines MPI_Isend() and MPI_Irecv(), do I solve the problem? Or is there any way of increasing the available buffer size?
Thanks in adavance.
scicomex
Old   April 15, 2005, 10:03
Default Re: MPI buffer size for Send/Recv
Joe
I had a similar problem with my code. The fix for me was to use Isend and Irecv. Make sure you use a MPI_Waitall at an appropriate place to insure all the messages are complete.
Old   April 15, 2005, 11:21
scicomex
Thanks very much! I will try that.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
