Question regarding non-uniform FVM staggered grid |
June 17, 2011, 05:39 |
TWB
Rep Power: 19 |
I have a question regarding non-uniform FVM staggered Cartesian grid. When the grid is non-uniform, I believe there are 2 ways to discretize the volume of the u/v grid, assuming the p grid is created. 1. The east/west faces of the u grid intersects the cell center of p. In that case, the distance of the east/west faces from the cell center of u will be different. the volume of u and p cells are different. 2. The west face of the u grid intersects the cell center of p but the east face does not. The volume of the u cell and p cell are equal, except shifted. In that case, the distance of the east/west faces from the cell center of u will be different. Are these 2 discretizations sound? Is there any preferences of one over another? Thanks |
June 17, 2011, 10:05 |
private
I think there's a real advantage in having the cell faces coincide with the p locations (cell centers). Try a simple one-d steady state heat conduction problem as an easy-to-derive example. With fixed temperatures at each end, this problem has a simple analytic solution. Expand your two differencing choices in Taylor series and example the lower-order terms that you truncate. One of the two choices will have a leading truncated term that grows as 1 over dt for a non-uniform mesh!
June 18, 2011, 17:18 |
TWB
Rep Power: 19 |
thanks for your explanation.
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
buoyantSimpleRadiationFoam | msarkar | OpenFOAM | 0 | February 15, 2010 06:22 |
Problems with Turbulence Modeling | ezsoal | OpenFOAM Running, Solving & CFD | 4 | November 26, 2009 15:12 |
RasInterFoam STRANGE RESULTS AT BOUNDARY | kumar2 | OpenFOAM Running, Solving & CFD | 8 | March 24, 2008 18:38 |
Incompressible flow solver (staggered grid) | J. Ehrhard | Main CFD Forum | 1 | October 8, 1998 19:47 |
