Using sliding mesh for unsteady turbomachinery problem
Old   June 17, 2011, 07:43
Default Using sliding mesh for unsteady turbomachinery problem
happyman is on a distinguished road
I am currently modeling a turbine using periodic functions so my domain is one stator/rotor/stator arrangement. Having used mixing planes for steady calculations i now am running unsteady calculations and from what i have researched i need to apply a mixing plane for this. My problem is the periodicity of each zone must be the same, however i have 26 stators (on each set upstream and downstream of rotor) and 30 rotor blades so it is not. I do not have the computational power to model the full wheel so need to scale the stator zones somehow. Do i just scale dimensions in the radial plane and leave height as is or how do i do it? Do i need to scale inputs or results from the zone? Or is there an easier way? Previously i have modeled unsteady flow on this problem using mixing plane but it only works uni-directionally and not bi-directionally (as is the nature of this flow).
Thanks in advance for any help.
happyman is offline   Reply With Quote
Old   June 20, 2011, 10:00
A. S.
apoorv is on a distinguished road
May be I can help; also you could be help for me, drop a mail shukla_apoorv1975@yahoo.co.uk or alternately we can have a chat on gtalk
apoorv is offline   Reply With Quote
Old   June 23, 2011, 06:53
Anyone else have any suggestions?
Old   July 8, 2011, 14:29
Docfreezzzz is on a distinguished road
If you have the capability for a half rotor simulation you can do a 15 rotors/13 stators passage simulation. You could also add a stator blade and do a third passage simulation of 10 rotors/9 stators. This shouldn't increase the stator section solidity by very much and is a very common strategy for running turbomachinery applications. In my experience, the mass flow through the machine is affected very little by adding an additional stator blade to find a common denominator in blade counts. Typically on the order of 1% or so.
CFD engineering resource
Docfreezzzz is offline   Reply With Quote
sliding mesh, turbomachinery, unsteady flow
Sliding mesh model problem Usman FLUENT 9 January 30, 2015 05:37
Sliding mesh problem Michel FLUENT 1 January 15, 2009 10:18
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
