Reason for oscillating residuals
Like Tree4Likes
  • 1 Post By fayaazhussain
  • 3 Post By julien.decharentenay
Old   June 21, 2011, 13:40
Unhappy Reason for oscillating residuals
Fayaaz Hussain
fayaazhussain is on a distinguished road
Dear all,
I would like to know the reason behind oscillating residuals. I am trying to simulate flow through a CD nozzle. I had mesh which gave me a converged solution for a pressure ratio of 6. The same mesh was useless with other pressure ratios. I got a error code 255 or error code 1 in ansys cfx. I remeshed by making a little coarser mesh. It works fine with pressure ratio 5. But my residuals started oscillating at the end but somehow managed to converge. The same mesh is being used for a pressure ratio 0f 4 but my residuals are oscillating badly. I heard that a very fine mesh could be one of the reasons for oscillations but my mesh seems to be coarse in my point of view. Can anybody help me in understanding the reasons behind the oscillations? Thanks in advance
Blakbeard likes this.
fayaazhussain is offline   Reply With Quote
Old   June 21, 2011, 18:56
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Hi Fayaaz,
There are large numbers of reasons why residuals may oscillate, below are a couple of ideas/reasons:
1) The physic of the flow dictates that there is no steady-state solution, only transient ones. Therefore once the solution is within the transient behavior, the residuals oscillates. Coarsening of the mesh may help with this problem. The "appropriate" way is to conduct a transient simulation and time-average it - but it is time expensive;
2) The code implementation (some random if statement) means that the flow is switching between 2 (or more) different models/limiters and the like. This creates oscillation in residuals.
You should look at convergence beyond residuals, i.e. monitoring of the flow field and variable of interest, and look at the area of large residuals (by plotting the residuals distribution).
Regards,
Julien
julien.decharentenay is offline   Reply With Quote
Old   June 27, 2011, 12:51
Casey
meangreen is on a distinguished road
lower your under relaxation facrors (URFs). Osciallting residuals (genearlly) means the solution is changing too much between iterations and overshooting the solution.
meangreen is offline   Reply With Quote
Old   August 21, 2014, 10:31
Marcel Jay
marcel_jay is on a distinguished road
Originally Posted by fayaazhussain View Post
Dear all,
I would like to know how you define a coarse or fine mesh.
My mesh for example has about 700k elements in a quite simple geometry. Would that be too fine?
Cheers
marcel_jay is offline   Reply With Quote
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 03:59
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
