March 26, 2005, 04:00 |
Opensource CFD
Hi, I'm searching for a comprehensive opensource CFD package. I've found OpenFOAM, Openflower and ADFC. Can anyone suggest anything better? I'm mainly interested in parallel solution of incompressible turbulent flows. Thanks Ashfaque
March 27, 2005, 04:27 |
Re: Opensource CFD
i think the openfoam is the best opensource software.
April 1, 2005, 09:07 |
Re: Opensource CFD
I've downloaded OpenFOAM, but I'm having problems to compile it. Does anybody knows how to get wmake for linux? I have only the gnu make, and it seems that wmake is avaiable only for windows. Is it right?
April 1, 2005, 09:29 |
Re: Opensource CFD
This is shipped with OpenFOAM.
Basically, you should follow these steps (make sure you do as much sanity checking after each step as you possibly can because this is not standard GNU build): 1) unpack the general pack into ~/OpenFOAM. You will get something like: /home/coyote/hjasak/OpenFOAM/OpenFOAM-1.1 2) Unpack the auxiliary tools into the directory: ~/OpenFOAM/linux You definitely need the gcc compiler, some post processing (always comes in handy) and java (if your native version is different): coyote*375-> cd ../linux /home/coyote/hjasak/OpenFOAM/linux coyote*376-> ls total 117M drwxr-x--- 16 hjasak foam 4.0K 2004-10-06 13:42 cmake-2.0.3 drwxr-x--- 4 hjasak foam 4.0K 2004-04-27 09:11 dx-4.3.2 drwxr-x--- 9 hjasak foam 4.0K 2005-01-06 05:52 gcc-3.4.3 drwxr-x--- 8 hjasak foam 4.0K 2004-12-13 17:38 gdb-6.2.1 drwxr-x--- 9 hjasak foam 4.0K 2004-07-06 07:52 j2sdk1.4.2_0 drwxr-x--- 5 hjasak foam 4.0K 2005-03-14 06:37 paraview-1.8.5 3) copy ~/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/ into your home directory and add the following line into your .cshrc: source $HOME/.OpenFOAM-1.1/cshrc (there is an equivalent for bash if you really must) 4) source ~/.cshrc and do some checking. For example: coyote*378-> which g++ /home/coyote/hjasak/OpenFOAM/linux/gcc-3.4.3/bin/g++ coyote*379-> which wmake /home/coyote/hjasak/OpenFOAM/OpenFOAM-1.1/wmake/wmake 5) Now we're close. Try running foamInstallationTest /home/coyote/hjasak/OpenFOAM/OpenFOAM-1.1/bin/foamInstallationTest and analyze the reported problems (if any). Once you're happy, do the following: foam ; ./Allwmake coyote*381-> foam /home/coyote/hjasak/OpenFOAM/OpenFOAM-1.1 coyote*382-> ./Allwmake and the whole thing should build. There is some build documentation in the release + a forum for questions of this kind - have a look at: http://tfdpc67.tfd.chalmers.se/cgi-bin/foam/discus.cgi Good luck, Hrv |
April 3, 2005, 05:33 |
Re: Opensource CFD
what is your linux version
April 11, 2005, 13:42 |
Re: Opensource CFD
SuSE 9.2 with kernell 2.6
Display Modes | |
CFD Wiki - We Need More Help! | Jonas Larsson | Main CFD Forum | 0 | September 26, 2005 09:11 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 05:49 |
Since Last June | John C. Chien | Main CFD Forum | 3 | July 12, 1999 10:38 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
