hydrodynamic drag and pressure drop of subchannels
Old   June 24, 2011, 12:37
Default hydrodynamic drag and pressure drop of subchannels
chenxi
chenxi05 is on a distinguished road
I am simulating the pressure drop coefficient of different subchannels, such as typical
cell, side cell, corner cell, at spacers grids. Generally, there are two methods to get the drag coefficient of blockage in a subchannel composed by rod bundles.
Because of the mass, momentum, and energy exchangement between the subchannels, it’s extremely inaccurate to get drag coefficient of subchannels over the second method.
Cd=Fd/0.5*rho*v*v*ref_area, Fd = force_z()@BLOKAGE(1)
Cd=dp/0.5*rho*v*v, (2)
In order to get Fd, you need to get force integral on surfaces of blockage, so we consider it as hydrodynamic drag coefficient;
In equation (2), we consider it as pressure drop coefficient.
Above all, I wanna ask the following questions:
1, are the two coefficients the same?
2, how to define the ref_area? According to the flow in channels, should we define the ref_area with the cross section area?
chenxi05 is offline   Reply With Quote
Pressure drag, friction drag and total drag? Cheng CFX 9 January 26, 2024 13:46
Relaltionship between pressure drop and drag force Li Main CFD Forum 5 March 4, 2017 16:04
Pressure drag calculation lc05 Main CFD Forum 2 November 1, 2010 07:50
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 12:30
Pressure drop and flow drag Li FLUENT 6 April 23, 2005 13:33
