Roughness vs. drag
Old   April 11, 2005, 09:40
Default Roughness vs. drag
pastras
Hi, can you suggest me your opinion on this question: when an external body with roughness surfaces has a lower drag than a smooth body (skin of dolphin or shark), can I use the same idea for an internal flows in pipes? Can I decrease a pressure drop of pipe with roughness walls? If yes, can I solve it by CFD codes and what turbulence model for core and near wall I must use?
Many thanks for your commentary
Old   April 12, 2005, 15:01
Default Re: Roughness vs. drag
Mani
I suppose it depends on the mechanism of drag reduction and if the same mechanism is still effective in pipe flow. As far as I remember, in your example of shark skin, the spatial scale of significance is so small that most people who did CFD on this kind of problem applied at least LES or even DNS. The purpose of those studies was to explain the mechanism of drag reduction. Maybe you should survey the literature. A turbulence model may not be good enough to capture such a small-scale effect.
Pressure drag, friction drag and total drag? Cheng CFX 9 January 26, 2024 13:46
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
Ideas for modelling effect of roughness on drag? andy2O CFX 13 January 18, 2009 18:30
NACA standart roughness DAK565656 Main CFD Forum 2 August 24, 2005 00:47
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
