April 14, 2005, 01:54 |
Floating point error-invalid number
Would any one know why they appeal the message "Floating point error-invalid number" whenever I try to shown the contour. Thanks so much.
April 14, 2005, 04:40 |
Re: Floating point error-invalid number
In particular if there is 1/x and x=0.
April 17, 2005, 20:49 |
So where should have that problem, do you have any ideas that where it come from?
April 18, 2005, 04:42 |
Probably bad code. If it's yours, use a debugger to trap the error. If you bought it, report the error to your vendor.
Specifically, if it's your code and it's written in Fortran, check that all your functions/subroutines have IMPLICIT NONE in them. |
April 18, 2005, 08:52 |
If this is a commercial plotting package like tecplot make sure you're not passing it results from a failed CFD run. That's the message tecplot spits out when you try to plot results from a run that has blown up.
April 18, 2005, 19:52 |
Re: Debugger ? Where can I find it?
Hi Steve,
YOu talking about debugger, where about in Fluent? Please point it out for me, thank you. Huong |
April 19, 2005, 07:56 |
If it's Fluent spewing out bad values, send the problem to them. That's why you pay them.
March 12, 2010, 10:43 |
floating point error
#8 | |
nisrin
Hi, I have been receiving this messege since long time" floating error" I did contact fluent people and no one is replying to my question. Is there any body who can help me, or is there anyone who can give me the right contact info for fluent people. thanks |
February 7, 2012, 22:12 |
Hello, i am getting floating point error: invalid number. My thesis train moving in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com
thanks |
April 1, 2013, 16:40 |
Floating point error: invalid number
hi all, I had same problem in fluent with a difference that my geometry is bended tube and my fluid is petroleum that part of this non-newtonian liquid is evaporate and this is two phase flow model - mixture.
I solve this problem by change (x or y direction) vector direction for mixture to Normal boundary in boundary condition menu for inlet and i use adaption to solve this problem. of course some times the ram are fulled when iteration is done or cpu or hardware is weak. for more help or detail go to following links http://cfdonline.ir/forum/showthread.php?tid=119 http://www.cfd-online.com/Wiki/Fluent_FA...void_it.3F good luck dears |
July 29, 2014, 05:57 |
#11 |
B_Kia
Rep Power: 11 |
could you fix it Mr Sheikh Nasir ?! i have been working on this error for about 3 months but i could not ((
July 29, 2014, 06:01 |
#12 |
B_Kia
Rep Power: 11 |
Could any body here fix this error ? please help me I need it quick , my email : bkianoush@mail.kntu.ac.ir
July 30, 2014, 07:42 |
#13 |
B_Kia
Rep Power: 11 |
Does any body here can help me ? i really need fix this peoblem
July 21, 2017, 03:24 |
#14 |
Yoo Rin
Rep Power: 8 |
Hi HyperNova. Have you fix your problem?
July 23, 2017, 10:54 |
#15 |
B_Kia
Rep Power: 11 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
