Validation of pressure/tempature with measured pre
Old   May 17, 2005, 05:24
Default Validation of pressure/tempature with measured pre
MH Kim
I am doing the CFD work for exhaust receiver(similar to exhaust manifold) of 2-stroke large engine and I have to validate the calculated pressure/temperature at several monitoring locations with measured pressure/temperature from sensor.
The validation includes both cycle average value of pressure/temperature and pressure trace.
Due to the inconsistency between CFD and measurement method, I am thinking there should be a kind of special treatment to compare them.
Therefore, I'd like to get some guide for validation of pressure/temperature.
For example, use of mass weighted averaged pressure/temperature instead of direct comparison of calculated pressure/temperature.
Validation test for 2d euler equations in subsonic regime with canonical squares panou Main CFD Forum 2 August 24, 2011 15:21
Comparing measured values with LES results N. A. OpenFOAM 3 June 27, 2011 07:05
Validation of Star CCM+ iand Siemens 2 December 8, 2010 06:59
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
Urgent: RAE 2822 validation NID Main CFD Forum 0 September 3, 2004 10:34
