2D incompressible turbulent flow
Old   May 21, 2005, 05:15
Default 2D incompressible turbulent flow
na
Dear for all, I'm going to simulate the steady incompressible turbulent flow arrond an airfoil. There are many Formulations such as : Mac method, Simple, piso...etc. But wath is the best one for these kind of problemes? Thanks for your response in advance
Old   May 21, 2005, 09:52
Default Re: 2D incompressible turbulent flow
versi
If MAC, SIMPLE, PISO are equally unfamiliar to you, Choose SIMPLE for popularity. MAC requires Catesican grids.
Old   May 22, 2005, 08:59
na
Thanks versi for your response. It is not an equation, that is unfamiliar or no for me. I surch what is the suimple method regarding the other ones. For Mac method is then employed in generalised coordinates.
Old   May 23, 2005, 04:41
Nick
MAC - is the most simple, SIMPLE - most popular. I've worked on both and if you use a turbulence model (k-e or RSA), i'd suggest using SIMPLE. Have you tried LES or DNS? I've tried Piso, but not much luck, I'm afraid.
Old   May 23, 2005, 10:28
na
very thanks Nick, Yes, I surch the eseay method. For steady incompressible turbulent flow I'm going to start with k-epsilon model and finaly the LES method.
Old   June 2, 2005, 11:02
General interest
the physics of 2D turbulence ( e.g. thin films ) is completely different to 3D turbulence. I'd read a little more before going down this investigation route. Your simulations will not capture the inverse cacade of 2D turbuelnce as K-E model assumed dissipation which does not occur in 2D turbulence!
Hope this helps!
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 03:46
laminar and turbulent flow in one simulation msna FLUENT 0 January 27, 2007 17:35
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
