Time step size for 3 D natural convection
Old   May 5, 2005, 14:42
Default Time step size for 3 D natural convection
hawk
Hi! All.
I am not so sure on how to decidee the time step size in Finite Volume Method for 3 D natural convection (laminar flow) case. Could you please give me some information?
Thanks.
Old   May 5, 2005, 18:50
Default Re: Time step size for 3 D natural convection
Kiddo
It's about the time for flow passing from inlet to outlet.
Old   May 6, 2005, 02:01
Willpin
I THINK YOU NEED TO TRY FROM THE SMALL TIME STEP TO LARGE TIME STEP UNTIL IT CAN NOT CONVERGE
Old   May 6, 2005, 13:33
Mani
I am assuming your question refers to solving the unsteady equations with a real "time step" and not the steady equations with "iteration steps".
In general there are two reasons why the time step is important: numerical stability and accuracy. The first one is an issue only with explicit time marching, and the answer to your question will depend on the scheme you are using. The second one (accuracy) is actually more difficult to address. You'll need to know a little bit about the flow before you can decide what "small" and "large" even means, regarding the time step. For starters, it would be good to know some fundamental length and velocity in your problem, which could help you define a fundamental time scale. I suppose a proper velocity might not be easy to define in the case of natural convection, but you might start with a steady-state solution.
Then, when you are going to resolve some unsteady phenomenon (vortex shedding for example), you'll need to roughly know what (range of) frequencies to expect. Of course, you don't need to know this in exact terms, but estimations are needed to get you started. Experimental data on similar problems might help you out, here. Once you have a reasonable (but inaccurate) unsteady solution, you can refine your time step to increase accuracy.
Old   May 9, 2005, 04:44
dpshaka
you use a implicit method or explicit method .
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
General grid/element size and time step questions stu CFX 1 May 24, 2007 05:37
