3D Incompressible shear flow-Pressure correction
Old   June 13, 2005, 12:55
Default 3D Incompressible shear flow-Pressure correction
Saurav Mitra
Hi, I am trying to use the pressure-correction technique(projection method) to solve 3D Incompressible shear flow. I have zero derivatives at the boundaries for the velocities. Since I am enforcing continuity through the Poission Equation for Pressure,I dont need boundary conditions for pressure. Initially I am trying to simulate a plug flow.Time stepping is Adam-Basforth and I am using central difference for spatial derivaties.My velocities are blowing up by orders of magnitude after the initial few time steps. I had been trying to resolve this problem for some months now and now it had turn out to be a nerve-wrecking experience for me.I don't know where I am going wrong.Did anybody tried to simulate a 3D Incompressible Flow on similar lines . I would be glad if you share your experiences. Thanks Saurav
Old   June 13, 2005, 15:06
Default Re: 3D Incompressible shear flow-Pressure correcti
ag
How are you treating the flux derivatives? If you are centrally differnecing those then your scheme will be neutrally stable at best and this could be your problem.
Old   June 13, 2005, 17:44
zxaar
i had similar problem, my solver used to work perfectly fine with structured meshes and when i tried to use it with unstructured meshes, the converging solution would blow up same as you mentioned. and yes it took me three months to find the solution. originally i was thinking the bug is in the orthogonal correction and with unstructured meshes non orthogonolity creating trouble, so i implemented all the possible treatments of these terms but no avail. finally it turns out that the problem was the way i was calculating gradients. i was also using central differences for calculating gradients.
anyway you can drop me email to talk more about this issue. i think i will be help.
Old   June 13, 2005, 18:57
Junseok Kim
Why don't you use linear interpolation boundary value for the boundaries for the velocities.
Old   June 13, 2005, 23:31
agg
Are you using a staggered grid arrangement? If not, you will have unstable solutions (Read more in textbook by Patankar). To remedy this you will have to add a fourth order dissipation term to your poisson equation or use rhie-chow interpolation.
Have you looked at your solution immediately after the first time step? If solution looks bad near boundaries, it could be a boundary issue.
Good Luck.
Old   June 13, 2005, 23:41
Saurav Mitra
It is a staggered grid formulation. Thanks Saurav
Old   June 13, 2005, 23:47
shekharc
I also had similar problem....however, rather than meshing up in finding out the subtle wrongs and likewise stuffs, I decided to solve pressure-poisson equation to obtain the pressure field (staggered grid, cylindrical co-ordinate, central difference, MAC) and I got a stable solution immediately. I implemented what was suggested in the original MAC paper by Horlow and Welch.
Old   June 13, 2005, 23:52
agg
You mentioned that you do not need a boundary condition for pressure. Why is that? For a second order pressure poisson equation, you will need two boundary conditions in each direction. Normally a dirichlet or a Neumann condition is used.
Old   June 14, 2005, 02:51
andy
Without explcitily imposing boundary conditions for pressure the matrix for the pressure equation is singular. Since you only want pressure gradients and not pressure itself this is not a problem and quite normal. However, in order to get a solution for the pressure field (to within an arbitrary constant) the RHS must integrate exactly to zero. If not, every iteration of the solver the average level of the pressure will be pushed up or down because there are no boundary conditions to prevent this.
Simply add a loop to add up the mass errors and check that it is a roundoff number. If not, scale your outflow velocities so they exactly match your inflow velocities. For incompressible flow you cannot pump in more/less mass than flows out so the ajustment is required on physical grounds as well.
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Operating pressure for incompressible flow ??? tobino FLUENT 0 August 29, 2011 18:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
