June 13, 2005, 03:24 |
Kiva help needed
Does some body have experience of KIVA in using this for gas turbine application.
I have 2d flow behinf triangualr bluff body. I have problem how to set the boundary condition.. Can anybody help me. Pratap |
June 13, 2005, 03:50 |
Re: Kiva help needed
hi pratap,
using input file (iprep) for kiva preprocessor, you can try to divide your computational domain into several blocks. if you have a triangular body, try to arrange the blocks so that each surface of the triangle corresponds with one boundary of certain block. this boundary is set as a solid boundary (face=2.0). i hope it helps cheers zaki |
June 13, 2005, 05:17 |
I do not have any problem with my mesh. But the problem is how to set the boundary condition in running the case using Kiva 3v.
Pratap |
June 15, 2005, 11:28 |
does anyone knows the website for Kiva?
July 5, 2005, 00:52 |
http://www.lanl.gov/orgs/t/t3/codes/kiva.shtml Try KIVA3V in google and you will end up with this one as well.
mesh converter in KIVA 4 | DaIN | Main CFD Forum | 0 | June 7, 2010 12:54 |
Kiva 3v , cgs library. | chat1983 | Main CFD Forum | 0 | December 3, 2009 05:26 |
Help needed in KIVA 3v | Srinivas | Main CFD Forum | 4 | September 15, 2009 16:50 |
PDF - conserved scalar approach in KIVA | vega | Main CFD Forum | 0 | July 5, 2005 02:49 |
kiva f90 information needed | Pratap | Main CFD Forum | 0 | November 10, 2004 10:21 |
