October 9, 2011, 07:10 |
Grid types and change of angle of attack
Corrado
Rep Power: 17 |
Hi all,
I wonder if C-grid or O grids are the only solution for analyzing airfoils under change of angle of attack without rotate the airfoil itself ( that is without rotate the geometry and re-meshing again). Is the same task possible with standard rectangular domains ( where I have velocity inlet, pressure outlet and symmetry up and bottom as boundary conditions ) ? Thank you |
October 9, 2011, 12:07 |
Corrado
Rep Power: 17 |
Hi Far ,
thank you for your reply. Do you mean that it is sufficient to input the components (u,v) of inlet velocity , keeping other boundary conditions unchanged ? Or have I to change the type of some boundary condition ? For high angles of attack , the fact that v component of velocity has a steep angle respect to the (vertical) inlet of a rectangular domain, doesn't affect the analysis ? Thanks |
October 9, 2011, 14:51 |
I would rather use velocity inlet bc on top and bottom too. You can change inlet velocity rather than mesh, no problems. Just make sure that near-field wake does not go to low-resolution mesh region under high aoa.
October 9, 2011, 17:51 |
#5 | |
Corrado
Rep Power: 17 |
left side, bottom,top= velocity inlet right side = pressure outlet ? |
October 10, 2011, 09:57 |
#6 | |
If your angle of attack is really huge, i.e. a such that wake goes to the top side, rather than into the outlet, you could change role of the sides and put outlet on the top and velocity inlet on the right, but I think the latter is not your case. Hope it helps Truffaldino |
October 10, 2011, 11:56 |
#7 | |
Corrado
Rep Power: 17 |
Thank you very much for your helpful posts |
change cell types | RX | Siemens | 9 | November 30, 2006 07:21 |
