TVD Schemes
Old   June 16, 2005, 05:08
Default TVD Schemes
Ritesh
Is there any TVD scheme, which can give second order accuracy even at sonic points or in the region of large gradients. It will be a great help if somebody tell me.
regards Ritesh
Old   June 16, 2005, 08:51
Default Re: TVD Schemes
Alexey
I think TVD can't give high accuracy (> 1-st) at the discontinuity. But WENO scheme can do it.
See
Jiang, G.,Shu C., Efficient Implementation of Weighted ENO Scheme, // J. Comp. Phys., (126), 1996, pp. 202-228.
Alexey.
Old   June 16, 2005, 09:10
andy
Why do you want second order accuracy at these points?
As a rule-of-thumb, if you have not used sufficient grid resolution to resolve gradients you will usually get worse solutions with high order schemes compared to low order schemes.
As another rule-of-thumb, what seems to work best in such regions are schemes which preserve relevant physical properties. Many schemes sacrifice one or more orders of accuracy (given the size of their computational molecule) even in resolved regions to gain better physical behaviour.
Old   June 16, 2005, 09:41
Salvador
Near a discontinuity there is no better resolution than first order and TVD schemes do just that. Near a sonic point, the problem is not the TVD scheme but the underlying numerical scheme (Roe's for example). If you are concerned about the amount of numerical dissipation of TVD schems try WENO or MP-WENO schemes.
Old   June 16, 2005, 10:12
Ritesh
Thanks for replying, actually I just wanted to have second order accuracy of at sonic points. Now I know it is not possible with TVD scheme, Infact today I read that it is impossible to have second order accuracy using TVD scheme in the book "Numerical Methods for Conservation Laws" by R. J. Levaque. Any futher suggetions? Thanks once again.
regards Ritesh
TVD Schemes in OF joern OpenFOAM Programming & Development 5 July 7, 2010 15:34
TVD schemes for acoustics Shuo Main CFD Forum 5 September 19, 2008 21:47
TVD schemes: 2 questions Shuo Main CFD Forum 0 August 19, 2008 21:51
TVD Schemes Sudeep FLUENT 0 October 14, 2000 21:31
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 04:21
