gas flow and heat transfer in porous media
Old   June 23, 2005, 21:01
Default gas flow and heat transfer in porous media
styoung317
Process:In a fixed-bed with only one port,gas flows in and reacts with the packed media,then reaction heat is released though the boundry. Question 1:Is Darcy's law proper to represent the flow(given that no steady flow with inlet and outlet exists)? Question 2:If the answer to question 1 is positive,or similar expression is adopted,whether the algorithm I proposed will do:first assume the gas velocity,then solve the governing equations for solid-phase temperature,gas-phase density and gas-phase temperature repectively,thereafter use gas state equation to obtain the gas pressure,finally renew the velocity by Darcy's law to complete one step of iteration.Is there anything special to pay attention to? Thank you,thank you very much!
Heat transfer within Porous Media Twiti CFX 10 January 15, 2021 08:13
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
