Boundary Layer - dimensionless wall distance y+
Old   October 31, 2011, 15:21
Default Boundary Layer - dimensionless wall distance y+
Martin R.
MartinRei is on a distinguished road
Hello everyone,
first of all, if that is the wrong forum for my question, i kindly ask the admins to correct that, because i was not sure where to post it.
I am currently trying to generate a boundary layer mesh for a laminar flow (Re<10000) over a 2D airfoil.
The question is now, how "high" should the first row of boundary layer cells be in this laminar flow? y_{1}^+ = 1 or y_{1}^+ = 30?
Kind regards,
Martin Rei
MartinRei is offline   Reply With Quote
Old   November 2, 2011, 01:10
Sonil Singh
Sonil is on a distinguished road
Martin
Choice of what value of y+ to take depends on how accurately are you trying to capture the flow in laminar sub-layer in a turbulent flow problem. If you make a mesh with y+ 30 then you will have to perform your simulation using a turbulence modelling with wall scales (this will approximated the effects of laminar sub layer and buffer zone numerically) fora turbulent flow. y+=1 or less must be used if you have enough computing power and you need not use wall scale in this case.
In your case of a low reynolds number flow these things may not matter... Still i would suggest mesh as fine as possible, as a high resolution mesh is always preferable if we have enough computing resource.
Sonil is offline   Reply With Quote
Old   November 2, 2011, 04:08
Martin R.
Originally Posted by Sonil View Post
Martin
[...] in a turbulent flow problem. [...]
Is it different in a laminar problem? Because the problem at hand is laminar.
Old   November 2, 2011, 05:57
Sonil Singh
See it all boils down to resolving your boundary layer...
I would suggest you to calculate B.L. thickness with respect to chord using formula for calculating B.L. thickness for laminar flow over flat plate and try to have minimum of 20 layers inside that length... and keep the growth ratio of the grid inside 1.15 in the B.L.
Old   November 3, 2011, 01:14
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by MartinRei View Post
Hello everyone,
Kind regards,
Martin Rei
Y+ is not a flow variable, it is by product of turbulence modeling and therefore it is meaning less in laminar flows. However, in laminar flows you should make the mesh independence study.
If the flow were turbulent, then in low reynolds number these things matter alot.
ps. If you refine mesh sufficienntly high, then you may reach the DNS with laminar flow solver !!!!
Far is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
